DRAFT help
Basic Analysis > Distributions > Distribution Platform Options
Publication date: 09/20/2024
The Distributions red triangle menu contains options that affect all of the reports and graphs in the Distribution platform.
Uniform Scaling
Scales all axes with the same minimum, maximum, and intervals so that the distributions can be easily compared.
Stack
Changes the orientation of the histogram and the reports to horizontal and stacks the individual distribution reports vertically. Deselect this option to return the report window to its original layout.
Arrange in Rows
Enter the number of plots that appear in a row. This option helps you view plots vertically rather than in one wide row.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
