You can download and install the JMP documentation add-in. The documentation add-in contains an individual PDF of each document in the JMP library and the JMP Documentation Library file. The JMP Documentation Library file is one PDF file that contains the individual book PDF files. It allows users to search all books in a single PDF file, similar to the JMP Online Help.
When installed, the documentation add-in adds the Documentation PDFs option to the Help menu and installs the PDF files on your machine. This enables you to access the documentation locally by selecting Help > Documentation PDFs. Download the available documentation add-ins from https://www.jmp.com/doc-addin.
The following table describes the purpose and content of each document in the documentation add-in.
Document Title |
Document Purpose |
Document Content |
JMP Documentation Library |
Provide one PDF of the other individual book PDF files. |
Includes all the JMP documentation in one PDF. |
Discovering JMP |
If you are not familiar with JMP, start here. |
Introduces you to JMP and gets you started creating and analyzing data, and sharing your results. |
Using JMP |
Learn about JMP data tables and how to perform basic operations. |
Covers general JMP concepts and features that span all of JMP, including importing data, modifying columns properties, sorting data, and using workflow builder. |
Basic Analysis |
Perform basic analysis using this document. |
Describes the following Analyze menu platforms: • Distribution • Fit Y by X • Tabulate • Text Explorer Covers how to perform bivariate, one-way ANOVA, and contingency analyses through the Analyze > Fit Y by X platform. Also addresses how to approximate sampling distributions using bootstrapping and how to perform parametric resampling with the Simulate platform. |
Essential Graphing |
Find the ideal graph for your data. |
Describes the following Graph menu platforms: • Graph Builder • Scatterplot 3D • Contour Plot • Bubble Plot • Parallel Plot • Cell Plot • Scatterplot Matrix • Ternary Plot • Treemap • Chart • Overlay Plot The book also covers how to create background and custom maps. |
Profilers |
Learn how to use interactive profiling tools, which enable you to view cross-sections of any response surface. |
Covers all profilers listed in the Graph menu. Analyzing noise factors is included along with running simulations using random inputs. |
Design of Experiments Guide |
Learn how to design experiments and determine appropriate sample sizes. |
Covers all topics in the DOE menu. |
Fitting Linear Models |
Learn about Fit Model platform and many of its personalities. |
Describes the following personalities, all available within the Analyze > Fit Model platform: • Standard Least Squares • Stepwise • Generalized Regression • Mixed Model • Generalized Linear Mixed Model • MANOVA • Loglinear Variance • Nominal Logistic • Ordinal Logistic • Generalized Linear Model |
Predictive and Specialized Modeling |
Learn about additional modeling techniques. |
Describes the following platforms in the Analyze > Predictive Modeling menu: • Neural • Partition • Bootstrap Forest • Boosted Tree • K Nearest Neighbors • Naive Bayes • Support Vector Machines • Model Comparison • Model Screening • Make Validation Column • Formula Depot Describes the following platforms in the Analyze > Specialized Modeling menu: • Fit Curve • Nonlinear • Functional Data Explorer • Gaussian Process • Time Series • Time Series Forecast • Matched Pairs Describes the following Analyze > Screening menu platforms: • Explore Outliers • Explore Missing Values • Explore Patterns • Response Screening • Predictor Screening • Association Analysis • Process History Explorer |
Multivariate Methods |
Learn how to analyze several variables simultaneously. |
Describes the following Analyze > Multivariate Methods menu platforms: • Multivariate • Principal Components • Discriminant • Partial Least Squares • Multiple Correspondence Analysis • Structural Equation Models • Factor Analysis • Multidimensional Scaling • Multivariate Embedding • Item Analysis Describes the following Analyze > Clustering menu platforms: • Hierarchical Cluster • K Means Cluster • Normal Mixtures • Latent Class Analysis • Cluster Variables |
Quality and Process Methods |
Learn about tools for evaluating and improving processes. |
Describes the following Analyze > Quality and Process menu platforms: • Control Chart Builder and individual control charts • Measurement Systems Analysis (EMP and Type 1 Gauge) • Variability / Attribute Gauge Charts • Process Screening • Process Capability • Model Driven Multivariate Control Chart • Legacy Control Charts • Pareto Plot • Diagram • Manage Limits • OC Curves |
Reliability and Survival Methods |
Learn to evaluate and improve reliability in a product or system and analyze survival data for people and products. |
Describes the following Analyze > Reliability and Survival menu platforms: • Life Distribution • Fit Life by X • Cumulative Damage • Fatigue Model • Recurrence Analysis • Repeated Measures Degradation • Destructive Degradation • Reliability Forecast • Reliability Growth • Reliability Block Diagram • Repairable Systems Simulation • Survival • Fit Parametric Survival • Degradation • Fit Proportional Hazards |
Consumer Research |
Learn how to study consumer preferences and create better products and services. |
Describes the following Analyze > Consumer Research menu platforms: • Categorical • Choice • MaxDiff • Uplift • Multiple Factor Analysis |
Genetics |
Learn how to analyze your genetic data to simulate a breeding program to predict the optimum genetic crosses to make. |
Describes the following Analyze > Genetics menu platforms: • Marker Statistics • Marker Simulation |
Scripting Guide |
Learn about the powerful JMP Scripting Language (JSL). |
Covers a variety of topics, such as writing and debugging scripts, manipulating data tables, constructing display boxes, and creating JMP applications. |
JSL Syntax Reference |
Learn about the JSL function arguments and messages. |
Includes syntax, examples, and notes for JSL commands. |
Keyboard Shortcuts |
Learn how to use your keyboard to quickly navigate JMP and complete tasks. |
Includes commands and the corresponding keystrokes for Windows and Apple macOS. |
Menu Descriptions |
Learn what items are in the menus in JMP. |
Describes the menu options for Windows and Apple macOS. |
