DRAFT help
Publication date: 09/20/2024
Edit or Run an Application
To open an application for editing, select File > Open, select the .jmpappsource file, and then select Open.
Note: If the Table property is empty or the specified data table cannot be found, the application runs anyway but objects requiring the data table will fail to create and JMP displays a warning.
To run an open application, click the Application Builder red triangle and select Run Application.
To run a closed application, select File > Open, select the .jmpapp file, and then select Open.
On Windows, you can also open or run an application from the JMP Home Window by doing one of the following:
Drag the file from Windows Explorer onto the JMP Home Window or onto a blank application window.
Double-click the file in Recent Files list.
Right-click either the .jmpappsource or the .jmpapp file and select either Edit Application or Run Application.
