DRAFT help
Essential Graphing > Contour Plots > Example of a Contour Plot
Publication date: 09/20/2024
To create a contour plot, you can use either the Contour platform or Graph Builder. This section provides examples for both.
To see the example using the Contour platform, see Example Using the Contour Platform.
To see the example using Graph Builder, see Example of a Contour Plot in Graph Builder.
