DRAFT help
Basic Analysis > Distributions > Additional Examples of the Distribution Platform > Example of Testing Probabilities for Two Levels
Publication date: 09/20/2024
This example shows you how to create a Test Probabilities report in the Distribution platform for a variable with exactly two levels.
Initiate the Test Probabilities Report
1. Select Help > Sample Data Folder and open Penicillin.jmp.
3. Select Response and click Y, Columns.
4. Click OK.
5. Click the Response red triangle and select Test Probabilities.
Figure 3.15 Test Probabilities Report Options for a Variable with Exactly Two LevelsĀ
Generate the Test Probabilities Report
1. Type 0.5 in both Hypoth Prob fields.
2. Click the probability less than hypothesized value button.
3. Click Done.
Exact probabilities are calculated for the binomial test.
Figure 3.16 Examples of Test Probabilities Reports for a Variable with Exactly Two LevelsĀ
