DRAFT help
Predictive and Specialized Modeling > Explore Missing Values > Explore Missing Values Platform Options
Publication date: 09/20/2024
The Explore Missing Values red triangle menu contains the following options:
ADI Loading Matrix
(Available only for the ADI method.) Shows or hides a report that contains the columns that correspond to the factor loading for each component.
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
Save By-Group Script
