DRAFT help
Design of Experiments Guide > The Fit Group Orthogonal Supersaturated Platform > Fit Group Orthogonal Supersaturated Platform Options
Publication date: 09/20/2024
The Fit Group Orthogonal Supersaturated Design platform red triangle menu contains platform options.
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
