DRAFT help
Publication date: 09/20/2024
Get a List of Filenames
To obtain a list of filenames in a specific directory, use the Files In Directory function.
Files In Directory( path, <recursive( 0 | 1 )> );
Both filenames and subdirectory names are returned as shown in the following example:
Files In Directory( "$SAMPLE_DATA" );
{ "2D Gaussian Process Example.jmp", "Abrasion.jmp", ... "Design Experiment", "Detergent.jmp", ... }
Notice that the files within the Design Experiment subdirectory are not included. And only files in the root $SAMPLE_DATA directory are listed.
To return a list of all file names, add the optional recursive(Boolean) argument to Files In Directory:
Files In Directory( "$SAMPLE_DATA", recursive( 1 ) );
{ "2D Gaussian Process Example.jmp", "Abrasion.jmp", ... "Design Experiment/2x3x4 Factorial.jmp", "Design Experiment/Algorithm Data.jmp", ... }
To get the full pathnames, recurse the directories and concatenate the file paths and file names. The following example loops through each file in the $SAMPLE_DATA directory and subdirectories. The file path is concatenated to each file name.
names = Files In Directory( "$SAMPLE_DATA", recursive( 1 ) );
For( i = 1, i <= N Items( names ), i++,
	names[i] = Convert File Path( "$SAMPLE_DATA" ) || names[i]
names;
{"/C:/Program Files/JMP/JMP/19/Samples/Data/2D Gaussian Process Example.jmp",
"/C:/Program Files/JMP/JMP/19/Samples/Data/Abrasion.jmp", ... }
The Files in Directory command accepts native and POSIX paths, as well as paths using path variables. See “Path Variables” for more information about working with paths.
