DRAFT help
Publication date: 09/20/2024
Group Summary of Time
If a time column is specified, the Time Series Forecast report contains a section of summaries of the individual time series. The summaries contain the following information for each time series:
<Grouping Column Name>
(Available only if a Grouping variable is specified.) The level of the grouping variable that defines the individual series when data is provided in the stacked format.
N Rows
The number of observations in the series.
Missing Value
Indicates whether any of the time values are missing values.
Unique Timestamps
Indicates whether the time stamps are unique.
Start
The starting time stamp.
End
The ending time stamp.
Missing Record
Indicates whether there are observations missing from the data table, based on the starting and ending time stamps and the data resolution/pattern.
Tip: The Group Summary of Time table is linked to the Select Series list. When you select a series in the Group Summary of Time table, the corresponding entries are also selected in the Select Series list.
