DRAFT help
Publication date: 09/20/2024
Informative Missing
In the Fit Model launch window, the Informative Missing option constructs a coding system that allows estimation of a predictive model despite the presence of missing values. It codes both continuous and categorical model effects.
Continuous Effects
When a continuous main effect has missing values, a new design matrix column is created. This column is an indicator variable, with values of one if the main effect column is missing and zero if it is not missing. In addition, missing values for the continuous main effect are replaced with the mean of the nonmissing values for rows included in the analysis. The mean is a neutral value that maintains the interpretability of parameter estimates.
The parameter associated with the indicator variable estimates the difference between the response predicted by the missing value grouping and the predicted response if the covariate is set at its mean.
For a higher-order effect, missing values in the covariates are replaced by the covariate means. This makes the higher-order effect zero for rows with missing values, assuming that Center Polynomials is checked (the default setting). This is because Center Polynomials centers the individual terms involved in a polynomial by their means.
In the Effect Tests report, each continuous main effect with missing values has Nparm = 2. In the Parameter Estimates report, the parameter for a continuous main effect with missing values is labeled <colname> Or Mean if Missing and the indicator parameter is labeled <colname> Is Missing. Prediction formulas that you save to the data table are given in terms of expressions corresponding to these model parameters.
Categorical Effects
When a nominal or ordinal main effect has missing values, the missing values are coded as a separate level of that effect. As such, in the Effect Tests report, each categorical main effect with missing values has one additional parameter.
In the Parameter Estimates report, the parameter for a nominal effect is labeled <colname>[ ]. For an ordinal effect, the parameter is labeled <colname>[-x], where x denotes the level with highest value ordering.
As with continuous effects, prediction formulas that you save to the data table are given in terms of expressions corresponding to the model parameters.
Coding Table
When you are using the Standard Least Squares personality, you can view the design matrix columns used in the Informative Missing model by selecting Save Columns > Save Coding Table.
