Use the JSL function Python Install Packages('python_module') to install external packages. The following examples install the Pandas package for use in other scripts.
Names Default To Here( 1 );
Python Install Packages( 'pandas' );
Install multiple packages at once by delimiting the package names with a space.
Python Install Packages( 'pyarrow pandas' );
Python packages that are pure Python scripts will have no trouble installing. However, some packages that need to compile source code to build a dynamic library may need to use the jpip wrapper to install correctly.
jpip, a pip wrapper script designed for JMP can be created with the JSL command Python Create JPIP CMD();.
The following example creates the jpip wrapper then installs the scikit-learn package from the command line.
1. Generate the customized jpip wrapper script with JSL or JMP’s Python Editor:
A directory picker dialog opens to choose the destination directory for jpip.
2. Open a terminal or command prompt:
– On Windows, use Command Prompt or PowerShell.
– On Apple macOS, use the Terminal.
3. Install scikit-learn using jpip:
– jpip install --user --no-warn-script-location sklearn
The Python package scikit-learn can now be used in JMP’s Python environment.
For packages that still fail to install, you must install a Python 3.11.x environment, use pip to compile them, then use JMP’s jpip wrapper to install them.
1. Install a Python 3.11.x release from https://www.python.org/downloads/.
3. Navigate to the location of your Python installation.
4. Install the package using pip to compile the package locally:
– pip install python_module
5. Navigate to the location of the jpip wrapper.
6. Install the package to the JMP Python environment:
– jpip install --user python_module
