DRAFT help
Discovering JMP > Introducing JMP
Publication date: 09/20/2024
Introducing JMP
Basic Concepts
JMP (pronounced jump) is a powerful and interactive data visualization and statistical analysis tool. Use JMP to learn more about your data by performing analyses and interacting with the data using data tables, graphs, charts, and reports.
JMP enables researchers to perform a wide range of statistical analyses and modeling. JMP is equally useful to the business analyst who wants to quickly uncover trends and patterns in data. With JMP, you do not have to be an expert in statistics to get information from your data.
For example, you can use JMP to do the following:
Create interactive graphs and charts to explore your data and discover relationships.
Discover patterns of variation across many variables at once.
Explore and summarize large amounts of data.
Develop powerful statistical models to predict the future.
Figure 2.1 Examples of JMP Reports
Contents
JMP Concepts That You Should Know
How Do I Get Started with JMP?
First Looks
Using Sample Data
Understand Data Tables
Understand the JMP Workflow
Step 1: Perform the Analysis and View Results
Step 2: Remove the Box Plot from a JMP Report
Step 3: Request Additional JMP Output
Step 4: Interact with JMP Platform Results
How is JMP Different from Excel?
Structure of a Data Table
Formulas in JMP
JMP Analysis and Graphing
