DRAFT help
Scripting Guide > Python > Python Syntax Reference > jmp Package Constants
Publication date: 09/20/2024
The JMP package offers the following constants for accessing common file paths used by JMP as well as version numbers for JMP and the JMP package for Python.
File path constants are written in upper case, a convention familiar for Python constants.
jmp.__jmp_version__
Description
Returns the version number of the currently running instance of JMP.
jmp.__version__
Description
Returns the version number of the JMP package for Python.
jmp.ALL_HOME
Description
Returns the file-path referred to by JMP’s $ALL_HOME path variable.
jmp.BUILTIN_SCRIPTS
Description
Returns the file-path referred to by JMP’s $BUILTIN_SCRIPTS path variable.
jmp.DESKTOP
Description
Returns the file-path referred to by JMP’s $DESKTOP path variable.
jmp.DOCUMENTS
Description
Returns the file-path referred to by JMP’s $DOCUMENTS path variable.
jmp.DOWNLOADS
Description
Returns the file-path referred to by JMP’s $DOWNLOADS path variable.
jmp.HOME
Description
Returns the file-path referred to by JMP’s $HOME path variable.
jmp.PY_USER_APPDIR
Description
Returns the file-path to the user directory location acting as the base of JMP’s Python support. The site-packages directory is within this directory hierarchy.
jmp.PYTHON_EXE
Description
Returns the file-path to the JMP installed Python executable.
jmp.SAMPLE_APPS
Description
Returns the file-path referred to by JMP’s $SAMPLE_APPS path variable.
jmp.SAMPLE_DASHBOARDS
Description
Returns the file-path referred to by JMP’s $SAMPLE_DASHBOARDS path variable.
jmp.SAMPLE_DATA
Description
Returns the file-path referred to by JMP’s $SAMPLE_DATA path variable.
jmp.SAMPLE_IMAGES
Description
Returns the file-path referred to by JMP’s $SAMPLE_IMAGES path variable.
jmp.SAMPLE_IMPORT_DATA
Description
Returns the file-path referred to by JMP’s $SAMPLE_IMPORT_DATA path variable.
jmp.SAMPLE_PROJECTS
Description
Returns the file-path referred to by JMP’s $SAMPLE_PROJECTS path variable.
jmp.SAMPLE_SCRIPTS
Description
Returns the file-path referred to by JMP’s $SAMPLE_SCRIPTS path variable.
jmp.TEMP
Description
Returns the file-path referred to by JMP’s $TEMP path variable.
jmp.USER_APPDATA
Description
Returns the file-path referred to by JMP’s $USER_APPDATA path variable.
