DRAFT help
Welcome to JMP > Learn about JMP > JMP Technical Support
Publication date: 09/20/2024
JMP technical support is provided by statisticians and engineers educated in JMP, many of whom have graduate degrees in statistics or other technical disciplines.
Many technical support options are provided at https://www.jmp.com/support, including the technical support phone number.
