DRAFT help
Multivariate Methods > Latent Class Analysis
Publication date: 09/20/2024
Group Observations of Categorical Variables
Latent class analysis enables you to find clusters of observations for categorical response variables. A latent variable is an unobservable grouping variable. Each level of the latent variable is called a latent class. The Latent Class Analysis platform fits a latent class model and determines the most likely cluster or latent class for each observation. In most situations, a subject matter expert uses the results of a latent class analysis to create definitions for each latent class based on the characteristics of the class.
Figure 16.1 Example of Latent Class Analysis
Contents
Overview of the Latent Class Analysis Platform
Overview of Platforms for Clustering Observations
Launch the Latent Class Analysis Platform
The Latent Class Analysis Report
Cluster Comparison Report
Latent Class Model Report
Latent Class Analysis Platform Options
Latent Class Model Options
Additional Example of the Latent Class Analysis Platform
Statistical Details for the Latent Class Analysis Platform
Statistical Details for Latent Class Model Fit
Statistical Details for the Maximum Number of Clusters
