DRAFT help
Consumer Research > Categorical Response Analysis > Launch the Categorical Platform
Publication date: 09/20/2024
Launch the Categorical platform by selecting Analyze > Consumer Research > Categorical.
Figure 3.9 Categorical Platform Launch Window for the Simple Tab
For more information about the options in the Select Columns red triangle menu, see “Column Filter Menu” in Using JMP.
