DRAFT help
Predictive and Specialized Modeling > Matched Pairs Analysis > Launch the Matched Pairs Platform
Publication date: 09/20/2024
Launch the Matched Pairs platform by selecting Analyze > Specialized Modeling > Matched Pairs.
Figure 20.3 The Matched Pairs Launch Window
For more information about the options in the Select Columns red triangle menu, see “Column Filter Menu” in Using JMP.
Y, Paired Response
Provide the two response columns. For information about analyzing more than two responses, see Multiple Y Columns.
X, Grouping
Provide a grouping variable to compare the differences across groups. See Across Groups.
Weight
Identifies one column whose numeric values assign a weight to each row in the analysis.
Freq
Identifies one column whose numeric values assign a frequency to each row in the analysis.
By
Performs a separate matched pairs analysis for each level of the By variable.
After you click OK, the Matched Pairs report window appears. See The Matched Pairs Report.
