DRAFT help
Profilers > Profiler > Launch the Prediction Profiler Platform
Publication date: 09/20/2024
The Prediction Profiler can be accessed from the Graph menu or the red triangle menus of certain platforms.
The Prediction Profiler can be accessed directly from the Graph menu. When you access the Prediction Profiler in this way, the Prediction Profiler launch window appears. See “Profiler Launch Windows”.
The Prediction Profiler can be accessed as a red triangle menu option in many modeling platforms. See “Where to Find JMP Profilers” for more information about the availability of the Prediction Profiler in different platforms.
The Prediction Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu.
Image shown hereThe Prediction Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu.
