DRAFT help
Basic Analysis > Simulate > Launch the Simulate Feature
Publication date: 09/20/2024
To launch the Simulate feature, right-click a column of calculated values in a JMP report window and select Simulate. To use the Simulate feature, the data table must contain a formula with a random component that simulates data. The Simulate option is available in many reports, including all reports that support bootstrapping.
Note: The Simulate feature is not available in reports that use a By variable.
