DRAFT help
Publication date: 09/20/2024
Life Distribution Report
The Life Distribution report enables you to analyze lifetime data where some time observations might be censored. The Life Distribution report contains the following content:
Event Plot
Compare Distributions in Life Distribution
Statistics for Life Distribution
Tip: If you find that the report window is too long, select Tabbed Report from the Life Distribution red triangle menu.
Figure 3.6 Example of the Life Distribution Report for Fan.jmp
