DRAFT help
Publication date: 09/20/2024
Make Table
Click Make Table to construct the choice study table or tables that you selected in Output Options. In the table panel of the Choice Profiles table, there is a Choice script. Run the script and then click Run Model to analyze your experimental results.
For information about the Choice Model report, see “Choice Model Report” in Consumer Research.
