DRAFT help
Predictive and Specialized Modeling > Make Validation Column > Make Validation Column Platform Options
Publication date: 09/20/2024
Image shown hereMake Validation Column Platform Options
The Make Validation Column red triangle menu contains the following options:
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
