A JMP add-in is a file that has the .jmpaddin extension. You can install it in one of two ways:
1. Select File > Open.
2. Navigate to the .jmpaddin file and select it.
3. Click Open.
You can also double-click the .jmpaddin file or drag it onto the JMP Home Window.
Select View > Add-Ins to see the add-ins that you have already installed.
Select View > Add-Ins, then use the Load Order arrows to move each add-in where you want it to appear in the Add-Ins menu.
If you are given an update to an add-in you already have installed, you can just install the update as you did the original add-in. Doing so overwrites the old version with the new one.
To temporarily disable an add-in without removing it
1. Select View > Add-Ins.
2. Select the add-in that you want to disable.
3. Deselect the Enabled check box.
4. Restart JMP.
To enable a disabled add-in
2. Select the add-in that you want to enable.
3. Select the Enabled check box.
To unregister an add-in
2. Select the add-in that you want to remove.
3. Click Unregister.
