The Mixture Profiler red triangle menu contains the following options:
Specify Factor Values
Opens a window that enables you to specify factor values. The entered values should sum to1. If needed, JMP adjusts the specified values to feasible settings. The option is also available from the Change button on the report window.
Show Points
Shows or hides the individual points on the ternary graph.
Show Current Value
Shows or hides the three-way crosshairs on the plot. The intersection of the crosshairs represents the current factor values. The Current X values above the plot give the exact coordinates of the crosshairs.
Show Constraints
Shows or hides the shading that results from any constraints on the factors. Those constraints can be entered in the Lo Limits and Hi Limits columns above the plot, or in the Mixture Column Property for the factors.
Up Dots
Shows or hides dots next to the contour lines. The dotted lines indicate the upward direction of the response values.
Number of Grid Points
Specifies the number of grid points on each of the three axes to use for the evaluation of contours.
Contour Grid
Opens a window that enables you to specify contour intervals for each response column. When you click OK, a contour grid is drawn on the profiler. The grid is based on the specified intervals.
Remove Contour Grid
Removes the contour grid that is overlaid on the profiler.
Factor Settings
A submenu of commands that enables you to save and transfer the Mixture Profiler settings to other parts of JMP. For more information about this submenu, see the discussion of the profiler in “Factor Settings”.
