DRAFT help
Essential Graphing > Graph Builder > Move or Remove Variables in Zones
Publication date: 09/20/2024
There are several ways that you can move a variable into a Graph Builder zone:
To move a variable from one zone to another, click and drag it from the old zone into the new zone.
To replace a variable in a zone, drag the new variable over the old one.
To switch a variable from one zone to another, right-click the variable in the zone that you want to move and select Swap. Then, select the variable that you want to switch places with.
To merge variables on the same axis, see Merge Variables on an Axis.
To remove a variable, drag it into empty space, or right-click the name of the variable in the zone and select Remove.
