DRAFT help
Publication date: 09/20/2024
Moving Range Options
In the Process Capability launch window, the options in this section enable you to specify which moving range statistic is used in the within sigma estimate when subgrouping is not used.
Note: When you specify subgrouping and click Calculate Between-and-Within Capability, use the Moving Range Options outline to specify which moving range statistic is used in the between sigma estimate.
Average of Moving Range
Uses the mean of the moving ranges to estimate sigma. The moving range is the difference between two consecutive points.
Median of Moving Range
Uses the median of the moving ranges to estimate sigma.
