DRAFT help
Predictive and Specialized Modeling > Naive Bayes > Naive Bayes Platform Options
Publication date: 09/20/2024
Image shown hereNaive Bayes Platform Options
The Naive Bayes red triangle menu contains the following options:
ROC Curve
Shows or hides the Receiver Operating Characteristic (ROC) curve for the model. The ROC curve is a plot of sensitivity versus (1 - specificity) for each level of the response variable. The ROC plot is shown by default. If you used validation, a plot is shown for each of the training, validation, and test sets. See ROC Curves.
Precision Recall Curve
Shows or hides the Precision-Recall Curve plot that contains a curve for each level of the response variable. A precision-recall curve plots the precision values against the recall values at a variety of thresholds. If you used validation, a plot is shown for each of the training, validation, and test sets. See “Precision-Recall Curve”.
Lift Curve
Shows or hides the lift curve for the model. If you used validation, a lift curve is shown for each of the training, validation, and test sets.
A lift curve shows how effectively response levels are classified as their fitted probabilities decrease. The fitted probabilities are plotted along the horizontal axis in descending order. The vertical coordinate for a fitted probability is the proportion of correct classifications for that probability or higher, divided by the overall correct classification rate. Use the lift curve to see whether you can correctly classify a large proportion of observations if you select only those with a fitted probability that exceeds a threshold value.
If the response has two levels, the Lift curve plot displays a lift curve for the first level of the response only. If the response has more than two levels, the Lift curve plot displays a sub-outline of the curves for each response level. See “Lift Curve” for more information about lift curves.
Save Predicteds
Saves a new column to the data table. The column contains the predicted classifications. The column is called Naive Predicted <Y, Response>.
Save Prediction Formula
Saves a new column to the data table. The column contains the prediction formula for the classifications. The column is called Naive Predicted Formula <Y, Response>.
Save Probability Formula
Saves new columns to the data table. The columns contain the formulas that are used to classify each observation. Three groups of columns are saved:
Naive Score <Class>, Sum
For each column that represents a class, this column gives a score formula that measures strength of membership in the given class. In the Naive Score Sum column., these scores are summed across classes. See Statistical Details for Saved Probability Formulas.
Naive Prob <Class>
For each class, this column gives a formula for the conditional probability that an observation is in that class. See Statistical Details for Saved Probability Formulas.
Gives the formula for the predicted class.
Publish Probability Formula
Creates probability formulas and saves them as formula column scripts in the Formula Depot platform. If a Formula Depot report is not open, this option opens the Formula Depot window. See “Formula Depot”.
Profiler
Shows or hides the prediction profiler, which is used to graphically explore the prediction equation by slicing it one factor at a time. The prediction profiler contains features for optimization. Changes in the factor values are reflected in the estimated classification probabilities. See “Profiler” in Profilers.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
