DRAFT help
Scripting Guide > Extending JMP > OLE Automation
Publication date: 09/20/2024
OLE Automation
Most of JMP can be driven through OLE automation. Please see the Automation Reference.pdf at https://www.jmp.com/en_us/support/jmp-documentation.html for more information about automating JMP. This document introduces how to automate JMP through Visual Basic and using Visual C++ with MFC. It also contains more information about the methods and properties that JMP exposes to automation clients like Visual Basic and Visual C++.
The JMP Samples/Automation folder contains several sample Visual Basic .Net, and Visual C# .Net files.
