The Preferences command on the File menu (on the JMP menu on Apple macOS) displays the Preferences window. See Figure 15.1. Each category is described in this chapter.
On Windows, changes that you make to preferences are stored in a version-specific JMP.PFS file located in one of the following folders:
C:\Users\<user name>\AppData\Roaming\JMP\JMP\19\
C:\Users\<user name>\AppData\Roaming\JMP\JMPPro\19\
On Apple macOS, the preferences are stored in com.sas.jmp.plist, which is located in ~/Library/Preferences/.
JMP looks for this file when you open the program and considers your changes to be the factory defaults. And all subsequent changes are stored in this file.
