DRAFT help
Predictive and Specialized Modeling > Statistical Details > Predicted Probabilities in Tree Methods
Publication date: 09/20/2024
The predicted probabilities for the Decision Tree and Bootstrap Forest methods are calculated as described below by the Prob statistic.
For categorical responses in Decision Tree, the Show Split Prob command shows the following statistics:
Rate
The proportion of observations at the node for each response level.
Prob
The predicted probability for that node of the tree. The method for calculating Prob for the ith response level at a given node is defined as follows:
Equation shown here
where the summation is across all response levels; ni is the number of observations at the node for the ith response level; and priori is the prior probability for the ith response level, calculated as follows:
priori = λpi+ (1-λ)Pi
where pi is the priori from the parent node, Pi is the Probi from the parent node, and λ is a weighting factor currently set at 0.9.
The method for calculating Prob ensures that the predicted probabilities are always nonzero.
