DRAFT help
Using JMP > JMP Preferences > Privacy Preferences
Publication date: 09/20/2024
Privacy Preferences
The Privacy preferences provide information about telemetry and the handling of unexpected errors. If you are running a trial version of the JMP software, you see a description of what is included in JMP telemetry data collection and have an option to check for problems when JMP launches. If you are running a regular version of JMP, you only have an option to check for problems when JMP launches.
A link to the privacy statement is also included.
Figure 15.31 JMP Privacy Preferences for the Regular Version of JMP
