DRAFT help
Publication date: 09/20/2024
Product Function
The Product() function is similar to Summation() except that it multiplies the body results rather than adding them. The syntax is the same as for Summation(). For example:
p = Product( i = 1, 5 , i );
returns 120, the result of 1*2*3*4*5.
In this example, the initial value of i is 1, the upper limit is 5, then all integer values of i up to 5 are multiplied.
Here is the equivalent in the Formula Editor:
Equation shown here
