DRAFT help
Publication date: 09/20/2024
Project Workspace
In a JMP project, you can see all currently open files in the Workspace tool pane. Reports appear under the corresponding data table. The active data table appears in bold.
Tip: To hide or show the Workspace tool pane, select Project > Show Workspace. To specify which tool panes appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panes.
In the Workspace tool pane, you can do the following:
Double-click a file to make it active.
Right-click a file to close it, hide it (removes the tab and dims the file name), bookmark it, and more.
