DRAFT help
Publication date: 09/20/2024
Regression Reports
In the Fit Least Squares report, the Regression Reports options (accessed from the Response red triangle menu) provide summary information about model fit, effect significance, and model parameters.
Summary of Fit
Shows or hides a summary of model fit. See Summary of Fit.
Analysis of Variance
Shows or hides calculations for comparing the fitted model to a simple mean model. See Analysis of Variance.
Parameter Estimates
Shows or hides a report containing the parameter estimates and t tests for the hypothesis that each parameter is zero. See Parameter Estimates.
Effect Tests
Shows or hides tests for the fixed effects in the model. See Effect Tests.
Effect Details
Shows or hides a report containing details, plots, and tests for individual effects. See Effect Details.
When the Effect Leverage Emphasis option is selected, each effect has its own report at the top of the Fit Least Squares report window. This report includes effect details options as well as a leverage plot. See Effect Leverage Plots.
Lack of Fit
Shows or hides a test assessing if the model has the appropriate effects, when that test can be conducted. See Lack of Fit.
Show All Confidence Intervals
Shows or hides confidence intervals for the following statistics:
Parameter estimates in the Parameter Estimates report
Least squares means in the Least Squares Means Table
AICc
Shows or hides AICc and BIC values in the Summary of Fit report. See “Likelihood, AICc, and BIC”.
