DRAFT help
Reliability and Survival Methods > Reliability Growth > Reliability Growth Platform Options
Publication date: 09/20/2024
The Reliability Growth red triangle menu contains the following options:
Fit Model
If the Time to Event Format, Dates Format, or Concurrent Systems data formats are specified in the launch window, this menu contains options to fit various Non-Homogeneous Poisson Process (NHPP) models. These options are described in detail below. Depending on the choices made in the launch window, the possible options are:
Crow AMSAA
Crow AMSAA with Modified MLE
Fixed Parameter Crow AMSAA
Piecewise Weibull NHPP
Reinitialized Weibull NHPP
Piecewise Weibull NHPP Change Point Detection
Fit Parallel System Model
If the Parallel Systems data format is specified in the launch window, this menu contains options to fit various models for multiple-prototype data. The possible options in this menu are dependent on choices made in the launch window.
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
Save By-Group Script
Model List
Once a model is fit, the Model List report appears. This report provides various statistical measures that describe the fit of the model. As additional models are fit, they are added to the Model List, which provides a convenient summary for model comparison. The models are sorted in ascending order based on AICc. The Model List report contains the following statistics:
Nparm
The number of parameters in the model.
-2Loglikelihood
The likelihood function is a measure of how probable the observed data are, given the estimated model parameters. In a general sense, the higher the likelihood, the better the model fit. It follows that smaller values of twice the negative of the log-likelihood (-2Loglikelihood) indicate better model fits.
AICc
The Corrected Akaike’s Information Criterion.
BIC
The Bayesian Information Criterion.
See “Likelihood, AICc, and BIC” in Fitting Linear Models for more information about -2Loglikelihood, AICc, and BIC.
