DRAFT help
Using JMP > Save and Share Your Data > Save Data Tables > Save JMP Data as a CSV File
Publication date: 09/20/2024
On Windows, JMP can convert data from a JMP data table to a comma-separated values (CSV) file. To save a data table as a CSV file:
1. With the specific data table open in JMP, select File > Save As.
2. Select CSV (Comma delimited) (*.csv) from the Save as type list.
3. Enter the file name.
4. Select the location for the CSV file.
5. Click Save.
Note: Exporting a data table to a CSV file uses the comma and carriage return line feed character (CRLF) as file delimiters. Use a different extension and later rename the file with the CSV extension if you need to use different delimiters.
