DRAFT help
Using JMP > Save and Share Your Data > Create Journals > Save Journals in Other Formats
Publication date: 09/20/2024
You can save a journal in another format (such as HTML or PDF). When you save the journal as HTML, buttons and links are active when the file is viewed in a web browser.
Note: The header and footer defined in your printer setup appears in the PDF file. However, you can set the left, center, and right header and footer in a JSL script. Search for the Set Print Footers message in the JMP Scripting Index. (Select Help > Scripting Index in JMP.)
Windows
1. Select File > Export.
2. Select the format. See Save Reports.
3. Click Next.
4. (Optional) Rename the file.
5. Save the file.
Apple macOS
3. Click Next.
4. Name and export the file.
