DRAFT help
Discovering JMP > Save and Share Your Work > Save Reports as Interactive HTML
Publication date: 09/20/2024
Interactive HTML enables you to share JMP reports that contain dynamic graphs so that even non JMP users can explore the data. JMP reports are saved as an interactive web page that you can share with others (for example, on a shared network drive, by email, or on a website). Users then explore the data as they would in JMP.
