DRAFT help
Publication date: 09/20/2024
Save the Diagram as a Data Table
Saving the Cause and Effect Diagram as a data table is a good approach if you have other processes that need to update the data table. However, very little customization of the diagram is available because the data table cannot represent the customization.
To save the diagram as a data table, perform the following steps:
1. Highlight the entire diagram in the Cause and Effect Diagram report.
2. Right-click and select Make Into Data Table.
3. Save the new data table.
