DRAFT help
Publication date: 09/20/2024
Scatterplot Matrix
The Scatterplot Matrix sub-report shows the histogram (and correlation plots when estimating epistasis), in which we can easily visualize the range estimates of relationship. A histogram skewed to the right (high values) indicate that most individuals have strong genetic similarity. On the contrary, if the histogram is skewed to the left (low values) indicate that most individuals have weak genetic similarity. See “Compare Multiple Variables Using Scatterplots” in Discovering JMP.
