DRAFT help
Using JMP > Get Started with JMP > Manage Files and Open Windows > Search for Recently Opened Files on Windows
Publication date: 09/20/2024
On Windows, recently opened files appear in the Home Window. You can also search for recently opened files from any JMP window.
Select File > Quick Open or press Alt+Shift+O to open the Filter box and enter your search term. This option also lets you view the path of the file. Press Esc or click the X button to close the window after you type a search term.
