DRAFT help
Publication date: 09/20/2024
Select Matching Row State Cells
You can select a cell in a row state column and then select all cells that contain the selected cell’s attributes. This option enables you to select cells with any combination of row state attributes, such as Exclude, Hide, color, or marker. For example, if a cell has a red marker and is excluded, and you select matching cells, all cells in excluded rows with red markers are selected.
1. Right-click the cell whose row state you want to select.
2. Select Select Matching Cells.
The cells with matching row states are selected.
