DRAFT help
Publication date: 09/20/2024
Image shown hereSet Number of Folds
This section of the Make Validation Column report enables you to specify K, the number of folds for K-Fold crossvalidation. The default and minimum value for K is 4 and the maximum value is the number of levels in the Grouping Columns, if specified. Specifying a grouping column that has less than four levels results in an error message.
