DRAFT help
Publication date: 09/20/2024
Share an Add-In
Once you have a .jmpaddin file, you can share the file with other users. Email the file or you place it in a shared location, such as a network folder, or on the JMP File Exchange (located online in the JMP User Community).
When JMP users open the file, the add-in files are extracted into the appropriate folder, and the add-in is registered and installed. The add-in now appears in the user’s JMP Add-Ins menu.
