DRAFT help
Quality and Process Methods > Control Chart Builder > Control Chart Types > Shewhart Control Charts for Variables
Publication date: 09/20/2024
In Control Chart Builder, control charts for variables are classified according to the subgroup summary statistic plotted on the chart.
XBar charts are a type of location chart that display subgroup means (averages).
R charts are a type of dispersion chart that display subgroup ranges (maximum – minimum).
S charts are a type of dispersion chart that display subgroup standard deviations.
Individual Measurement charts are a type of location chart that display individual measurements.
Run charts are a type of location chart that display individual measurements as a connected series of points.
Presummarize charts display both subgroup means and standard deviations.
Moving Range charts are a type of dispersion chart that display moving ranges of two successive measurements.
Note: If you remove a dispersion chart or turn off the preference Show Two Shewhart Charts in File > Preferences > Platforms > Control Chart Builder, only the location chart is shown. Any associated scripts will contain the JSL option Show Two Shewhart Charts set to off (0).
XBar, R, and S Charts
For quality characteristics measured on a continuous scale, a typical analysis shows both the process mean and its variability with a mean chart aligned above its corresponding R or S chart.
Individual Measurement Charts
Individual Measurement charts displays individual measurements. Individual Measurement charts are appropriate when only one measurement is available for each sampling time point. If you are charting individual measurements, the individual measurement chart shows above its corresponding moving range chart. Moving Range charts displays moving ranges of two successive measurements.
Presummarize Charts
If your data consist of repeated measurements of the same process unit, you can combine these into one measurement for the unit. Pre-summarizing is not recommended unless the data contain repeated measurements on each process or measurement unit.
Presummarize summarizes the process column into sample means and/or standard deviations, based either on the sample size or sample label chosen. Then it charts the summarized data based on the options chosen in the window.
Levey-Jennings Charts
Levey-Jennings charts show a process mean with control limits based on a long-term sigma. The control limits are placed at 3s distance from the center line. The standard deviation, s, for the Levey-Jennings chart is calculated the same way standard deviation is in the Distribution platform.
