DRAFT help
Using JMP > JMP Reports > Navigate JMP Reports > Show and Hide Parts of a JMP Report
Publication date: 09/20/2024
JMP reports are organized in a hierarchical outline. Each level of the outline has a triangle-shaped disclosure icon Image shown here that you can click to open and close report sections.
You can also change which columns appear in a report. Right-click the report and select the column from the Columns list. To select more than one column at once, press Alt before right-clicking.
