DRAFT help
Publication date: 09/20/2024
Show Summary Statistics
In the Multiple Correspondence Analysis platform, this option shows the Summary Statistics for the Column Points table or the Summary Statistics for the Row and Column Points tables. The Y table gives Quality, Mass, and Inertia for each level of each response, called a column point. The X table gives Quality, Mass, and Inertia for each level of the X, Factor variables. See Statistical Details for Summary Statistics.
X
Lists the columns specified as X, Factor variables.
Y
Lists the columns specified as Y, Response variables.
Category
Lists the levels of the X or Y variables.
Quality(dim=2)
Lists the quality of the representation of the level by the solution.
Mass
Lists the row frequency for the level of the response divided by the total frequency. In the Burt table, this is the Total % for each row.
Inertia
Lists the proportion of the total inertia accounted for by the level of the response. The inertia values sum to one across the levels and their responses.
Note: If there are columns specified as X, Factor variables, the Summary Statistics report displays tables of both X and Y with the same report headings.
