DRAFT help
Basic Analysis > Simulate > The Simulate Results Table > Simulated Power Report
Publication date: 09/20/2024
The Simulated Power report contains the following information:
Alpha
The significance level: 0.01, 0.05, 0.10, and 0.20.
Rejection Count
The number of simulations where the test rejects at the corresponding significance level.
Rejection Rate
The proportion of simulations where the test rejects at the corresponding significance level.
Lower 95% and Upper 95%
Lower and upper limits for a 95% confidence interval for the simulated rejection rate. The interval is computed using the Wilson score method. See Wilson (1927).
Tip: Increase the Number of Samples for a narrower confidence interval.
