DRAFT help
Quality and Process Methods > Control Chart Builder > Statistical Details for Control Chart Builder
Publication date: 09/20/2024
This section contains statistical details for Control Chart Builder.
Statistical Details for XBar and R Charts
Statistical Details for XBar and S Charts
Statistical Details for Individual Measurement and Moving Range Charts
Statistical Details for P, NP, and Laney P′ Charts
Statistical Details for U, C, and Laney U′ Charts
Statistical Details for Levey-Jennings Charts
Statistical Details for Short Run Control Charts
Statistical Details for G Charts
Statistical Details for T Charts
Statistical Details for Three Way Control Charts
Notes:
Control limits are calculated using a sigma multiplier, K, which is set to 3 by default. To change the default value of K, use the K Sigma option in the red triangle menu or the K Sigma preference in File > Preferences > Platforms > Control Chart Builder.
For sample sizes up to n = 50, JMP uses control chart constants d2(n) and d3(n) that are defined in Table 2 of Harter (1960). For samples with a sample size greater than 50, JMP uses the control chart constant values for sample size 50 in both the sigma and control limit calculations.
