DRAFT help
Publication date: 09/20/2024
Image shown hereStatistical Details for Estimation Methods
In the Generalized Regression personality of the Fit Model platform, the estimation methods include penalized regression methods, which introduce bias to the regression coefficients by penalizing them.
Image shown hereRidge Regression
Ridge regression applies an l2 penalty to the regression coefficients. Ridge regression coefficient estimates are defined as follows:
Equation shown here,
where Equation shown here is the l2 penalty, λ is the tuning parameter, N is the number of rows, and p is the number of variables.
Image shown hereDantzig Selector
The Dantzig Selector method applies an l norm to the inner products of the residuals and X columns. Coefficient estimates for the Dantzig Selector satisfy the following criterion:
Equation shown here
where Equation shown here denotes the l norm, Equation shown here is the l1 penalty, and t is the tuning parameter. The l norm is the maximum absolute value of the components of the vector v.
Image shown hereLasso Regression
The Lasso method applies an l1 penalty to the regression coefficients. Coefficient estimates for the Lasso are defined as follows:
where Equation shown here is the l1 penalty, λ is the tuning parameter, N is the number of rows, and p is the number of variables
Image shown hereElastic Net
The Elastic Net method combines both l1 and l2 penalties. Coefficient estimates for the Elastic Net are defined as follows:
This is the notation used in the equation:
α is a parameter that determines the mix of the l1 and l2 penalties
Tip: There are two sample scripts that illustrate the shrinkage effect of varying α and λ in the Elastic Net for a single predictor. Select Help > Sample Index, click the Sample Index red triangle, select Open Sample > Script, and select demoElasticNetAlphaLambda.jsl or demoElasticNetAlphaLambda2.jsl. Each script contains a description of how to use it and what it illustrates.
Image shown hereAdaptive Methods
The adaptive Lasso method uses weighted penalties to provide consistent estimates of coefficients. The weighted form of the l1 penalty is defined as follows:
Equation shown here
where Equation shown here is the MLE when the MLE exists. If the MLE does not exist and the response distribution is normal, estimation is done using least squares and Equation shown here is the solution obtained using a generalized inverse. If the response distribution is not normal, Equation shown here is the ridge solution.
For the adaptive Lasso, this weighted form of the l1 penalty is used in determining the Equation shown here coefficients.
The adaptive Elastic Net uses this weighted form of the l1 penalty and also imposes a weighted form of the l2 penalty. The weighted form of the l2 penalty for the adaptive Elastic Net is defined as follows:
Equation shown here
